ccna question
jonk34567
Level 4
Level 4
pls look at the image below. what is the answer ? also can i have a explanation for it ?
Deepak Kumar
The answer is A and C.
This is done by IPv4 summarization. Both are correct.
Your subnets 192.168.146.0/24, 192.168.147.0/24, 192.168.148.0/24, 192.168.149.0/24 are Aggregated.
summarization calculator:
https://cway.cisco.com/tools/RouteSummary/
Deepak Kumar
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
