CCNA Security Lab: Securing Layer 2 Switches Packet tracer issue
sinergycena
I am working with this laboratory
https://ccnasec.com/6-3-1-1-lab-securing-layer-2-switches-instructor-version.html
in Packet tracer but there is a part where the procedure hangs because it doesn't work. Next I show the Running config R1, SW1, SW2.
Running config R1
Building configuration...
Current configuration : 1227 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
ip dhcp excluded-address 192.168.1.1 192.168.1.4
ip dhcp excluded-address 192.168.20.1
ip dhcp pool CCNAS
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
ip dhcp pool 20Users
 network 192.168.20.0 255.255.255.0
 default-router 192.168.20.1
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX15243825-
spanning-tree mode pvst
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
 shutdown
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1.1
 encapsulation dot1Q 1 native
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/1.99
 encapsulation dot1Q 99
 ip address 192.168.99.1 255.255.255.0
interface GigabitEthernet0/2
 no ip address
 duplex auto
 speed auto
 shutdown
interface Vlan1
 no ip address
 shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
 login
end
Running config S1
version 12.2
hostname SW1
spanning-tree vlan 1 priority 0
interface FastEthernet0/1
 switchport trunk native vlan 99
 switchport mode trunk
 switchport nonegotiate
interface FastEthernet0/2
 shutdown
interface FastEthernet0/3
 shutdown
interface FastEthernet0/4
 shutdown
interface FastEthernet0/5
 switchport port-security
 spanning-tree portfast
interface FastEthernet0/6
 switchport access vlan 20
 switchport mode access
 spanning-tree bpduguard enable
interface FastEthernet0/7
 shutdown
interface FastEthernet0/8
 shutdown
interface FastEthernet0/9
 shutdown
interface FastEthernet0/10
 shutdown
interface FastEthernet0/11
 shutdown
interface FastEthernet0/12
 shutdown
interface FastEthernet0/13
 shutdown
interface FastEthernet0/14
 shutdown
interface FastEthernet0/15
 shutdown
interface FastEthernet0/16
 shutdown
interface FastEthernet0/17
 shutdown
interface FastEthernet0/18
 shutdown
interface FastEthernet0/19
 shutdown
interface FastEthernet0/20
 shutdown
interface FastEthernet0/21
 shutdown
interface FastEthernet0/22
 shutdown
interface FastEthernet0/23
 shutdown
interface FastEthernet0/24
 shutdown
 shutdown
 shutdown
interface Vlan1
 ip address 192.168.1.2 255.255.255.0
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
Running config S2
Current configuration : 1543 bytes
version 12.2
hostname SW2
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 spanning-tree guard root
 shutdown
 shutdown
interface Vlan1
 ip address 192.168.1.3 255.255.255.0
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
My problem is in the next step
Step 8: Move active ports to a VLAN other than the default VLAN 1.
Add the current active access (non-trunk) ports to the new VLAN.
S1 (config) # interface f0 / 6
S1 (config-if-range) # switchport access vlan 20
S2 (config) # interface f0 / 18
S2 (config-if) # switchport access vlan 20
At this point R1 there is no communication between R1> SW1> SW2> PCA> PCB
and the next step
Part 4: Configure DHCP Snooping
DHCP snooping is a Cisco Catalyst feature that determines which switch ports can respond to DHCP requests. It enables only authorized DHCP servers to respond to DHCP requests and distribute network information to clients.
Task 1: Set Up DHCP
Step 1: Set up DHCP on R1 for VLAN 1.
R1(config)# ip dhcp pool CCNAS
R1(dhcp-config)# network 192.168.1.0 255.255.255.0
R1(dhcp-config)# default-router 192.168.1.1
R1(config)# ip dhcp excluded-address 192.168.1.1 192.168.1.4
Step 2: Set up DHCP on R1 for VLAN 20.
R1(config)# ip dhcp pool 20Users
R1(dhcp-config)# network 192.168.20.0 255.255.255.0
R1(dhcp-config)# default-router 192.168.20.1
R1(config)# ip dhcp excluded-address 192.168.20.1
Task 2: Configure Inter-VLAN Communication
Step 1: Configure subinterfaces on R1.
R1(config)# interface g0/1
R1(config-if)# shutdown
R1(config-if)# no ip address 192.168.1.1 255.255.255.0
R1(config-if)# no shutdown
R1(config-if)# int g0/1.1
R1(config-if)# encapsulation dot1q 1
R1(config-if)# ip address 192.168.1.1 255.255.255.0
R1(config-if)# int g0/1.20
R1(config-if)# encapsulation dot1q 20
R1(config-if)# ip address 192.168.20.1 255.255.255.0
R1(config-if)# int g0/1.99
R1(config-if)# encapsulation dot1q 99
R1(config-if)# ip address 192.168.99.1 255.255.255.0
Step 2: Configure S1 interface f0/5 as a trunk port.
S1(config)# int f0/5
S1(config-if)# switchport mode trunk
S1(config-if)# switchport trunk native vlan 99
When doing this procedure in step 4, the F0 / 5 interface turns off and when trying to turn it on again it only stays on for 30 seconds and turns off again.
Note: I have not yet applied the security part of ip ssh to be able to work without using usernames and passwords
Can you help me understand what I am doing wrong?
I have done the whole procedure several times and connectivity is lost, I cannot restore it.
PKT file is attachment if you want to download it
Martin L
If you have done the whole procedure several times, then likely PT is at fault.  I am surprised PT can do DHCP Snooping at all.  I remember I had issues with Snooping in my CCIE lab until right version of IOS is used.  so far I have 2 issues:
1. I  do not see " ip dhcp snooping trust" on switch ports
2.  I can see you use IOS 12. but not 15 for switches; I think PT comes with IOS 15 for switch, find it and try it using switch IOS 15.
You could try this on CML (free via SandBox), although not sure if their version of L2-iosv supports snooping as well.
let us know how is goes;  I don't have access to PT software atm;
Regards, ML
**Please Rate All Helpful Responses **
i found the issue, port security in f0/5 enabled... thanks anyway for answer :)
