11-03-2011 03:39 PM - edited 03-07-2019 03:12 AM
hi:
i have a question about CDP neighbors.
from the topology below
R3 and R2 using same IP addre to connect each other .
so when i run "show cdp neighbor" R2 can still discover the R3 .
how did R2 discover R3, that does not make much sense here since both router were configured as same IP.
is it because CDP is layer 1 protocol ?
thanks for your help.
Solved! Go to Solution.
11-03-2011 04:10 PM
CDP is layer-2
have a look:
http://www.cisco.com/en/US/tech/tk962/technologies_tech_note09186a00801aa000.shtml
11-03-2011 03:45 PM
Perhaps a typo?? I dont think the 2 routers can have the same IP.
11-03-2011 04:10 PM
CDP is layer-2
have a look:
11-03-2011 04:27 PM
thank you guys.
11-03-2011 04:34 PM
Hi danna,
You are right when you say that you see the CDP information. the moment you bring up the interface and turn on CDP it starts talking on the multicast address.
In your case the point here is that you will see the information on only 1 device that one that gets the ip address first and the other one will start complaining about the duplicate ip address.
So you are partly right.
Kishore
