Challenge Wireless Configuration question
Jose Chinchilla
Hi,I'm not familiar with Packet Tracert but I'm setting a Wireless Configuration lab (Packet Tracert 6.1). I need to establish connection between PC-wifi1 and PC-wifi2, but I don't know why router R1 is failing with that. All connections are working, VTP is transparent
I guess need to configure static routes on R1.
Any help is appreciated.
PD: I've attached pkt file
Harsha A.
Hey there,
I tried looking into your setup.
The Wireless Router is using a DHCP scope that's not defined in the Router.
For example, your WRS2 was using DHCP scope of Network 172.17.40.x. This Network is not configured in your Router (Router on a Stick) and that's the reason you were not able to ping.
In your Router, you have only configured 3 VLANs 10, 30 and 88. Any VLAN other than this will not be routed.
Hope it made sense :)
Harsha
