Change default arp timeout for FTD interface
JayantaND
Visitor
I have a requirement where lower arp timeout is required. Default global FTD arp timeout is 4 hours.
Is it possible to change arp timeout for one interface without changing the global arp timeout?
No you cant as I know.
What you can try  is run EEM in flexconfig with timer 5 min (for example)
And action for this eem is clear arp entry for specific port.
Hard task but I think it solution here.
