change enable password using sdm
donnie
Hi all,
I am using sdm 2.5 for my cisco1811. Pls advise how i can change the enable password using the sdm gui.
I also notice that i have to key in the enable password when i access it via console. I can't access the console using login.
This is the case after i enable the following. THks in advance.
aaa new-model
aaa authentication login test local
aaa authorization network test local
aaa session-id common
Hope that helps:
Choose Configure > Additional Tasks > Router             Properties and click Edit if you want to change the             Hostname, Domain Name, Banner and Enable Secret Password properties for a             router.
