Change Wireless band
as00001111
Hey guys,
I have a wlc 2504 with some APs connected.
Is there a possibility to change the band of some APs from 2,4GHz to 5GHz only?
And where can I see which band is currently configured/active?
Thank in advance!
So my questions is: Can I configure the Cisco APs for just providing the 5GHz band and disable the 2,4 GHz band?
Wireless > Access Points > Radios > 2.4 Ghz.
On the right-hand side of each APs (in every radio) there is a blue box.  Hover the mouse over the blue box and choose Configure.
You can disable 2.4 Ghz on a per-AP basis or disable 2.4 Ghz on the WLAN-side.
5 Replies 5
Leo Laohoo
Wireless > Access Points > Radios.
You can enable or disable a radio of a specific AP through here.
Please don't forget to rate our useful posts.
mmh that doesn't work for me!
there isn't an option to configure the band..
Oh, you mean Flexible Radio Assignment (RFA)?
What is the model of the APs?   For FRA, the APs in question has to be the new 2800/3800 series APs.  To enable FRA, go to Wireless > Advanced > RF Management > Flexible Radio Assignment.
My APs are AIR-CAP2702I-E-K9.
So I don't have the FRA option.
ehm let me explain the whole problem:
There are two of the AIR-CAP2702I-E-K9 APs in one room that provide a Wifi SSID.
In this room, I have approximately 50 tablets which connect to that SSID.
Furthermore, there are 50 bluetooth devices that interact between each other.
And I always have bluetooth connection problems.
So Bluetooth is working on the 2,4GHz band.
My Cisco APs are working on the 2,4GHz band AND the 5GHz band.
I checked this with the Windows software inSSIDer.
So that the 2,4GHz band is free for bluetooth.
