Changeing flash: from read only to read write
Vikingplanet
good day.
i have a Catalyst 3650 that i was going to delete the config file from. and for som reason it was set up previously with the wrong enable password. so i went to ROMMON to delete the config file from there, but then i noticed that flash: was in read only mode and i cant delete the file because of it. so my question is. is there a way to change it to read write, and if so, how? or is there another way i can delete the config file?
switch: delete flash:nvram_config
Are you sure you want to delete "flash:nvram_config" (y/n)?y
File "flash:nvram_config" not deleted -- read only file system
switch: dir
List of filesystems currently registered:
              xmodem[0]: (read-only)
                null[1]: (read-write)
                  bs[3]: (read-only)
               flash[18]: (read-only)
                tftp[19]: (read-write)
Abheesh Kumar
Go to ROMMON and give a try with below commands
switch: flash_init
switch: load_helper
switch: set BYPASS_STARTUP_CONFIG=1
after entering boot command  you will get the initial config dialog and do the basic configuration and save. Then reload the switch and go to ROMMON and change the variable.
set BYPASS_STARTUP_CONFIG=0
If the above command didnt works try with the below
switch: set SWITCH_IGNORE_STARTUP_CFG=1
switch: set SWITCH_IGNORE_STARTUP_CFG=0
Abheesh
20 Replies 20
Abheesh Kumar
switch: flash_init
switch: load_helper
Abheesh
The second set of commands worked nicely,
thanks for the help :)
this is also not working. as not recognizing '=' sign
Sorry for the almost year later reply. In hopes that any one else come here looking for why the '=' doesn't work.
Use this command first...
set SWITCH_IGNORE_STARTUP_CFG then use
set SWITCH_IGNORE_STARTUP_CFG 1
The first command adds it to the Set Directory and the second command adds the value. You may be able to get away with doing it together in the same command but I separate them for practical use.
I have same Problem .But when i try to enter flash_init command it displays the following :
monitor: command "flash_init" not found.
Hi Frds,
i have 3650 in which i am not able to get the login screen on console and also via Telnet. see below logs
C3650 con0 is now available
Press RETURN to get started.
% Authentication failed
2 - when i am trying to do Password recovery Switch  boots in READ ONLY MODE and Load_HELPER is not available.
Booting...
Interface GE 0 link down***ERROR: PHY link is down
The system has been interrupted prior to initializing some
filesystems and loading the operating system software.
Console will be reset to 9600 baud rate, need to change terminal setting first.
The following commands will initialize the remaining filesystems,
and finish loading the operating system software:
flash_init
boot
switch:
3 ---- there is no Config.text file instead nvram_config file is available.
switch: dir flash:
Directory of flash:/
15489 drwx 4096 .
2 drwx 4096 ..
15490 -rw- 81992100 cat3k_caa-base.SPA.03.07.04E.pkg
15491 -rw- 5667516 cat3k_caa-drivers.SPA.03.07.04E.pkg
15492 -rw- 36656136 cat3k_caa-infra.SPA.03.07.04E.pkg
15493 -rw- 46349632 cat3k_caa-iosd-universalk9.SPA.152-3.E4.pkg
15494 -rw- 28904332 cat3k_caa-platform.SPA.03.07.04E.pkg
15495 -rw- 128582464 cat3k_caa-wcm.SPA.10.3.141.0.pkg
15496 -rw- 1236 packages.conf
46465 drwx 4096 virtual-instance
54209 drwx 4096 vman_fdb
69697 drwx 4096 dc_profile_dir
15497 -rw- 2097152 nvram_config
69699 drwx 4096 wnweb_store
15498 -rw- 1600 vlan.dat
1288658944 bytes available (359235584 bytes used)
switch:
4 ---- cannot delete NVram_config.
please let me know how to do the PAssword recovery in this CASE.
ankitsatya30
how to solve this issue? plz help
are you trying to recover 3560 switch
Abheesh
its 3650 switch. m trying to copy IOS file from USBflash to flash
Is dir usbflash: showing the list of files in usb, then boot from usbflash:
boot usbflash:<filename>
Abheesh
yes its showing. i have tried to boot from usbflash but again not allowing to copy files from USBflash to flash.
execute the below commands, Switch will boot from usbflash not from flash
i
Abheesh
You are in ROMMON mode right.???
yes i am in ROMMON mode. have tried to boot from USBflash but not getting in
