Changing Switchport Mode From Access To Trunk
johnlloyd_13
Level 9
Level 9
hi experts,
i have 2 3560 trunked together and currently working (by show cdp neighbor and ping). i would like to verify with you guys if changing the switchport mode from access (removing the switchport mode access and switchport access vlan x lines) to trunk (switchport mode trunk) will cause a temporary disconnection or outage on the other switch. below is the config i want to accomplish:
AS-01-ALPHA#sh run int g0/24
Building configuration...
Current configuration : 316 bytes
interface GigabitEthernet0/24
switchport access vlan 111
switchport trunk allowed vlan 111,1076
switchport voice vlan 1076
no logging event link-status
priority-queue out
mls qos trust dscp
no snmp trap link-status
spanning-tree portfast
end
AS-02-ALPHA#sh run int g0/24
priority-queue out
mls qos trust dscp
end
CHANGE TO:
priority-queue out
mls qos trust dscp
Hello John,
in the same session if you wait a few seconds after having added switchport mode trunk on the core facing switch (but before you did on remote end).
I did several times this kind of operation follow the steps on my first post.
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello John,
configure remote switch first and give the
swithport mode trunk as last command.
You may lose it.
Note A little refinement could be:
switchport trunk native vlan 111 to handle untagged frames in vlan111.
this should allow you to keep the connection to remote site switch
On another vty session configure the other switch port as L2 trunk.
At this point you should get them working.
Hope to help
Giuseppe
hi guiseppe,
on your statement, "You may lose it."
does this mean i would lose my telnet session on the remote switch after issuing the 'switchport mode trunk command'? am i able to re-connect on the same session (after waiting for few seconds) or do i need to open another one?
Hello John,
Hope to help
Giuseppe
thanks giuseppe!!! just wana make sure. before i config for speed and i lost my telnet session.
mariorui
johnlloyd_13,
Forming a trunk between the 3560's would require:
"switchport mode trunk"
One thing to note, is that this will also enable Dynamic Trunking Protocol or DTP. This is important to note because the 3560 default is to be "dynamic auto". This essentially means that the switch will wait for the opposing end to initiate the trunk. If both ends are set to "dynamic auto" a trunk will not form. To disable DTP frame from being generated on the trunk:
"switchport nonegotiate"
Entering this command will force the port to trunk. You would want to put this on both ends of a trunk.
To be safe, copy the vlan numbers that are currently traversing those interfaces that are to be modified to trunk, and make sure that you explicitly allow those on the trunk. To be safe, allow all vlans through, so to ensure connectivity. Once you have confirmed that both ends of the trunk are properly working and you can ping devices on those respective vlan, manually prune the trunk links by removing the unnecessary vlans from the trunk using the command:
"switchport trunk allowed vlan {add|all|except|remove} "
To verify the trunk is working properly issue the command:
"show interface trunk"
This will show you the port, mode, encapsulation, status, and native vlan.
You can also issue:
"show interface status"
If you need more info, see here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_46_se/configuration/guide/swvlan.html#wp1200245
Hope this helps!
- Mario Ruiz
