Changing the Trunk Mode to Access Mode on an Interface on Cisco Switch SG350
I have a Cisco SG350 Switch and on two Interfaces: Gigabitethernet25 and Gigabitethernet26 i had ran the following configuration:
#switchport mode trunk
But now i want to change the configuration on these two Interfaces to:
#switchport mode access
#switchport access vlan 119
It is not letting me switch the mode from Trunk to Access as when i am typing #no switchport mode trunk then i am getting Error: Incomplete; unrecognized command. So, kindly recommend which command should i run to disable #switchport mode trunk and enable #switchport mode access on these two interfaces.
Looking forward to hear from you.
Vik.
12 Replies 12
Giuseppe Larosa
Hello Vikram,
try to use directly the command
swithport access vlan 119
in interface configuration mode, if SG350 behaves like an IOS based switch you don't need to disable mode trunk you can change the mode on the fly directly.
Hope to help
Giuseppe
Dear Giuseppe,
I have already tried to use directly the command:
But when you do show run then it only shows:
switchport access vlan 119     but it doesnot show switchport mode access as i think the switchport mode trunk (which was done previously is still active) and when i type: no switchport mode trunk then it show unrecognized/incomplete command.
We have to make sure that switchport mode access shows up in the configuration.
So, kindly guide me accordingly.
Vik.
When i type the command: #no switchport mode trunk then it gives me the error: "%Wrong number of parameters or invalid range, size or characters entered". as i am trying to remove the trunk that was created earlier.
Vik
Martin L
if "no" did not take just do switchport mode access, then sw access vlan x
and what type of a switch is SG350?
Hi MartinLo,
I have tried #switchport mode access, then #sw access vlan 119 but still in show run it only displays:
switchport access vlan 119 but it doesnot display #switchport mode access
It is a Cisco SG350-28P 28-Port Gigabit PoE Managed Switch.
Herald Sison
Level 3
Level 3
you can simply type directly the command below:
but if you want to erase the config before you replace it just like what i always do you can simply type the command
then after that you can show run then see if the trunk is it still there
Dear Herald,
Vik
Hello
Try defaulting the port and re-apply the config
conf t
default interface x/x
interface x/x
switchport host
switchport access vlan x
exit
Kind Regards
Paul
Hi Paul,
default interface x/x command does not work on a SG350-28P PoE Managed Switch.
I have already tried the above command.
Hello
sh interface x/x switchport
ah interface x/x capabilities
Kind Regards
Paul
Dear Paul,
Both the commands:
did not work on this Cisco SG350-28P PoE Managed Switch.
Vik.
Dear Paul,
Both the commands:
Vik.
