Changing weight for MP-BGP
walter berris
Hi guys, I'm trying to manipulate a path selection in our IP/MPLS network. How can i change the weight on the local PE? or is it better for me to change the weight of that route on the other PE by using a export route-map? I had already tried changing the other route weight with the commands below, but when i ran the sh ip bgp vpnv4 vrf command it still showed the weight as 0.
access-list 46 permit 172.20.101.160 0.0.0.7
route-map IPBH_CHANGE_WEIGHT_OM permit 10
match ip address 46
set weight 32770
ip vrf 4G_BH_BMP01_REGION10_OM
export map IPBH_CHANGE_WEIGHT_OM
BMP-DIST-MPE01#sh ip bgp vpnv4 vrf SP_OMRAN_MPLS 172.20.101.72
BGP routing table entry for 10269:1010191:172.20.101.72/29, version 314907
Paths: (3 available, best #3, table SP_OMRAN_MPLS)
  Not advertised to any peer
  Local, imported path from 10269:1010186:172.20.101.72/29
    10.1.41.2 (metric 4) from 10.1.41.2 (200.32.198.121)
      Origin incomplete, metric 1, localpref 100, valid, internal
      Extended Community: RT:10269:1010190
        OSPF DOMAIN ID:0x0005:0x000000030200 OSPF RT:0.0.0.3:2:0
        OSPF ROUTER ID:172.20.35.10:0
      mpls labels in/out nolabel/35095
  Local, imported path from 10269:1010219:172.20.101.72/29
    10.1.41.4 (metric 3) from 10.1.41.2 (200.32.198.121)
      Extended Community: RT:10269:1010229
        OSPF ROUTER ID:172.20.35.18:0
      Originator: 10.1.41.4, Cluster list: 200.32.198.121
      mpls labels in/out nolabel/190
  Local, imported path from 10269:1010247:172.20.101.72/29
    172.20.35.29 (via 4G_BH_BMP01_REGION3_OM) from 0.0.0.0 (10.1.41.6)
      Origin incomplete, metric 1, localpref 100, weight 32768, valid, external, best
      Extended Community: RT:10269:1010256
        OSPF ROUTER ID:172.20.35.30:0
Network          Next Hop            Metric LocPrf Weight Path
* i172.20.101.72/29 10.1.41.2                1    100      0 ?
* i                 10.1.41.4                1    100      0 ?
*>                  172.20.35.29             1         32768 ?
BGP table version is 1153539, local router ID is 10.1.41.6
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external
Origin codes: i - IGP, e - EGP, ? - incomplete
      Origin incomplete, metric 1, localpref 100, valid, internal                                Would be preferred route....
* i                 10.1.41.4                1    100      0 ?                                       did not export the weight change to 32770
THANKS in advance.
5 Replies 5
seems the network defined in acl 46 is  incorrect
you gave defined access-list 46 permit 172.20.101.160 0.0.0.7 but it should be
172.20.101.72/29
few more info
what is the last mile routing protocol you are using between your CE and PE may be i can suggest something else if i have complete config
Hi Shirshendu, indeed the acl is incorrect, it should be 172.20.101.72, not 172.20.35.24. I have attached a drawing with the scenario, this is a redundant ring using ospf. There is a VRF configured on all 3 PEs and they are imported into the main VRF which is configured on the BMP PE. The network is up and working, i want to make the middle PE the best route for the 172.20.101.72 network. Presently it preferr BMP-DIST_MPE01 because it has a higher weight which is the default 32768. I know it chose that because 1. Its directly connected and 2. BGP selection WEIGHT. What i want to know is how to manipulate the weight by either;
1. change the weight of the route on the local PE to 0 or,
2. change and export the weight on the MPE02 to a higher value. (presently i have it configured with 32770 vlaue but it is not propagating in the BGP table as shown in the image, it stays at 0)
NOTE: i have not restart the BGP session. How can i clear MP-BGP session?
Thanks again for your help.
Try changing your ACL and clear ip bgp ..
Clear has to be done per neighbour or AS basis there is nothing to segregate as BGP or MBGP neighbours while clearing
However soft reset can be allowed on per neighbour whch will refresh the filters without beaking the neighbourship
To use feature of soft reset soft  infound have to be enable on the neighbour command under BGP
If this  dont work i do have some doubt yet.  I can sugget an alternate way
access-list 46 permit 172.20.101.72 0.0.0.7
match ip address 46
set local preference 150
route-map IPBH_CHANGE_WEIGHT_OM permit 20
**Please rate My solution if it helps You*****
Hello Walter,
weight is not a BGP or MP BGP attribute,  it is a local parameter that lives within a single router and  cannot be exported to any other device.
This is not a question of BGP vs. MP BGP.
In order to make the desired change you need a route-map applied inbound  in the vpnv4 address-family of the leftmost PE named  BMP-DIST-MPE01.
The route-map will be applied to the MP BGP session to the central PE and will rise the weight to a value greater then 32768
route-map RISE-WEIGHT permit 10
match ip address 46
set weight 40000
router bgp XX
address-family vpnv4
neigh  route-map RISE-WEIGHT in
Another possible option is to to make 0 the weight of the locally generated route on BMP-DIST-MPE01 and to rise the local preference on the central PE as Shirshendi is suggesting.
Hope to help
Giuseppe
