charts
Is there a chart to show what modules will fit what swithches for fiber applications
ex 2950 and 3560 switches
phiharri
Level 8
Level 8
Greetings John,
Here's the Gigabit Ethernet Transceiver Modules Compatibility Matrix which describes which types of transciever are compatible with specific switch models and the software requirements:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
It's also worth checking the Supported Hardware section of the release notes for the specific software releases you're using for any additional restrictions or caveats.
Hope this helps,
/Phil
