Cisc 3850 using WCCP redirect and VRF
CSCO11550753
Im trying to figure out if the Cisco 3850's do support the following commands by design:
***Queues***
ip wccp vrf xxxx 61
ip wccp vrf xxx 62
***Interface Config**
Interface gix/x
ip wccp vrf xxxx 61 redirect in
Interface gix/x
ip wccp vrf xxxx 62 redirect in
When trying to add the configuration its says its not supprted but on a Cisco 3750x this command set was supported. Cant understand why Cisco would take a step backwards. Any help or advice would be  greatly appreciated.
Cheers
Karl
0 Replies 0
