12-18-2016 10:23 PM - edited 03-08-2019 08:37 AM
can someone explain how to properly use both the ip interfaces and the switch interfaces on the Cisco 1811. I have tried to set the router up with vlans on the switch portion and ip addresses on the ip interfaces. That isn't the problem. When I try to communicate between the switch portion and the ip interface portion, I don't get the communication that i thought I would get. Is there something I need to understand? Because I can use two separate devices, (router and switch) and get the results that I need but not with the integrated device of the 1811.
Solved! Go to Solution.
12-19-2016 05:35 AM
Likely you need to define SVI(s) for your switch ports.
12-19-2016 05:35 AM
12-25-2016 03:00 AM
You have to define sub-interfaces toward the switch using the SVI and define a sub-interface for each VLAN with dot1q encapsulation.
Share your topology if you need any further assistance.
Wish you the best luck
