12-24-2010 09:33 AM - edited 03-06-2019 02:42 PM
Hello All, I recently purchased a used Cisco 182 router and experiencing some difficulty setting up the unit and navigating through to find some answers. First, I do not have a consloe cable at this time and that might be a significant cause of difficulty, however, I will let someone else verify that point. I was able to download theSDM file (2.5) and run the launcher. I can enter an IP address to get to a logon prompt, this is as far as I can go. I have not been able to determine if there is a factory "default" user & password. If there is, I have not been able to find a resource with this information. Any help with the basics at this point would be greatle appreciated. Thnak you for the assistance, GH
12-25-2010 09:32 PM
Cisco/Cisco12-27-2010 01:47 AM
DO remember that username password of cisco - cisco is just applicable for one time i.e. the first time you login. Do change the password immediately, else there is a good chance that the password of cisco will not work again.
