10-29-2012 11:59 AM - edited 03-07-2019 09:44 AM
Hallo and apologies for the very stupid question. What is the command to shutdown a cisco 1841 (say, to add a module)? I know how to reload / reboot, but the help does not seem to contain any command with an obvious name. Thank you a lot, I am left with the doubt that there is none, and that I should use the on-off power switch.
Solved! Go to Solution.
10-29-2012 12:01 PM
There is not a command. You can just power-off/on like you thought.
10-29-2012 12:01 PM
