Cisco 1905K9 - VLAN creation issue
azr.inamdar
Hello All,
I have Cisco 1905K9 router, Below is the show version and sh licence feature.
I am trying to create VLAN. But the router doesn't support. Can anyone suggest do I need to upgrade the router IOS? or what needs to done?
Also, I have to add more LAN ports for connectivity. Can I procure EHWIC card for this model of router?
ult01gwcsdnes01#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 05-Jun-15 12:31 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
ult01gwcsdnes01 uptime is 8 minutes
System returned to ROM by reload at 11:43:47 CST Fri Sep 2 2016
System image file is "usbflash0:c1900-universalk9-mz.SPA.154-3.M3.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1905/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FJC2033L0FJ
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO1905/K9 FJC2033L0FJ
Technology Package License Information for Module:'c1900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
data datak9 EvalRightToUse datak9
NtwkEss None None None
ult01gwcsdnes01#sh lice fea
Feature name Enforcement Evaluation Subscription Enabled RightToUse
ipbasek9 no no no yes no
securityk9 yes yes no yes yes
datak9 yes yes no yes yes
NtwkEssSuitek9 yes yes no no yes
ios-ips-update yes yes yes no yes
hseck9 yes no no no no
MEM-1900-256U512MB yes yes no yes yes
mgmt-plug-and-play yes no no no no
mgmt-lifecycle yes no no no no
mgmt-assurance yes no no no no
mgmt-onplus yes no no no no
mgmt-compliance yes no no no no
ult01gwcsdnes01#
"I will order the below EHWIC card and insert in my router for additional 4 Gigabit Ethernet ports. This will also enable the layer2 services including VLAN creation. right?"
-Yes
The below LAN card is compatible with Cisco 1905K9 right?
Product Number
Description
EHWIC-4ESG
4-port Cisco Gigabit EtherSwitch 10/100/1000BASE-TX autosensing EHWIC
-Yes
I am running the " Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)" - "usbflash0:c1900-universalk9-mz.SPA.154-3.M3.bin" with below packs active permanently. will this allow me to configure Ipsec over GRE tunnel?
-Yes, you should be good. For additional info visit "Cisco Feature Navigator"
http://tools.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
I hope this has been informative for you and please don't forget to rate our answers.
Please rate if helpful.
Thank you.
8 Replies 8
Austin Sabio
Level 4
Level 4
- CISCO 1905 is a serial ISR.
"The Cisco 1905 builds on the best-in-class offering of the Cisco 1841 Integrated Services Routers. All Cisco 1900 Series ISRs offer embedded hardware encryption acceleration, optional firewall, intrusion prevention, and advanced security services. In addition, the Cisco 1905 Integrated Services Router has a integrated serial interface module and a EWHIC slot which supports a choice of LAN, 3G or ISDN modules."
http://www.cisco.com/c/dam/en/us/products/routers/1905-serial-integrated-services-router-isr/data_sheet_c78-598372.pdf
- VLAN is a layer-2 entity.
EHWIC can provide you with LAN capabilities such as GigEth and Eth switching.
http://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/ic/hardware/installation/guide/oview_ic.html#68486
Thank you.
Hi Engineer_aus,
thanks for your reply.
So I understand that, I can add the EHWIC card to Cisco 1905K9 at EHWIC slot, right?
But i don't find any EHWIC card that support Cisco 1905K9.
Second part, do you mean to say, If i add a LAN card(EHWIC) to the router, will I be able to configure/create dynamic VLANs in the router?
I have activated the evaluation licences. Will they expire after 8 weeks and all my functionalities supported by those licences will go away?
Yes it is for that
Cisco says:
The EHWIC slot replaces the HWIC slot and can natively support HWICs and WAN interface cards
(WICs).
One integrated EHWIC slot is available on the Cisco 1905 for flexible configurat
ions supporting achoice of LAN, Serial, 3G, or ISDN modules.
Yes, the first link explain that this router has vlan capability and the secon explain how configure vlan
http://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/geshwic_cfg.pdf
If you have license: Evaluation and RighToUse, you can use it when will finish your time of evaluation, if your license is on Evaluation you use it until the period will finish.
Supported modules are listed in the datasheet page 8 in above link.
HWIC-4ESW Four port 10/100 Ethernet switch interface card
https://www.amazon.com/Cisco-HWIC-4ESW-EtherSwitch-High-Speed/dp/B000667NPI/ref=sr_1_1?ie=UTF8&qid=1472847324&sr=8-1&keywords=HWIC-4ESW
EHWIC-4ESG 4-port single-wide Gb Ethernet switch EHWIC
https://www.amazon.com/Cisco-EHWIC-4ESG-P-Enhanced-High-Speed-Interface/dp/B004640218/ref=sr_1_2?ie=UTF8&qid=1472847335&sr=8-2&keywords=EHWIC-4ESG+4-port
VLAN is a layer 2 term "switch". Once you add EHWIC card you can configure your switch module (including VLAN capability).
In regards to Evaluation License. you need to understand cisco ios licenses*. a PAK should be included in your order then get the license file from www.cisco.com/go/license.
*Good read
https://learningnetwork.cisco.com/docs/DOC-20321
And
http://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html#pgfId-1192406
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-border-element/qa_c67_462484.html
http://www.cisco.com/c/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/data_sheet_c78-556151.html
Thank you.
Thank you dmuinoorallo and engineer_aus.
So I understand that I can replace the HWIC slot on cisco 1905K9.
Product Number
Description
EHWIC-4ESG
I am running the " Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)" - "usbflash0:c1900-universalk9-mz.SPA.154-3.M3.bin" with below packs active permanently. will this allow me to configure Ipsec over GRE tunnel? Or Do I need to upgrade my IOS or any licensing ?
export@cisco.com.
1 terminal line
License Info:
License UDI:
Device# PID SN
I hope your respond when you insert your new card and configure vlans ;)
-Yes
Product Number
Description
EHWIC-4ESG
-Yes
Thank you.
Thank you engineer_aus. Much appreciated.
