CISCO 1941 router NAT problems
kmillard84
Hello all,
I am attemping to create a simple LAN and have computers on that LAN be able to access the internet.  I've configured my default ip route:
Gateway of last resort is 71.83.141.21 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 71.83.141.21
      71.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        71.83.141.20/30 is directly connected, GigabitEthernet0/1
L        71.83.141.22/32 is directly connected, GigabitEthernet0/1
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, GigabitEthernet0/0
L        192.168.1.1/32 is directly connected, GigabitEthernet0/0
192.168.1.0 is clearly my internal LAN while 71.0.0.0 is my external internet connection.  I am able to ping any internet site from the router, and I can connect as many computers as I want to the LAN without problems.  Computers can communicated with other computers on the network.  They just can't get out to the internet.
When I have done this before, i have used NAT to provide the linking.  I have the LAN interface indicated as nat inside and WAN interface as NAT outside.  However, when I put the ip nat inside source static network command in the running-config...i lose internet connectvitiy from the router.
Any ideas on what the issue is?  I'm sure its something small, but I can't figure out the issue.  Here's my running config...abbreviated.  It's very simple as I started over when I realized that i was having issues...and don't want to configure anything else until i get this resolved.
ip name-server 68.190.192.35
ip name-server 71.9.127.107
license udi pid CISCO1941/K9 sn FTX154800RY
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 71.83.141.xxx (redacted) 255.255.255.252
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 71.83.141.21
johnlloyd_13
Level 9
Level 9
Did you configure an ACL for your NAT? Try this:
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat inside source list 1 interface g0/1 overload
SOcchiogrosso
Level 4
Level 4
Yes you need an ACL to match the traffic you want to NAT and then you need your NAT statement telling the router to either NAT to an interface or a NAT pool.
Sent from Cisco Technical Support Android App
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
