Cisco 2511-RJ issues
Steven Williams
Level 4
Level 4
Ok I am starting to lose it here....My 2511-RJ has worked flawlessly for years and now its being funny. I thought it was RAM so I upgraded it to 16/16 but still the same issues. It gets to a point then just hangs...I cant even get a new IOS on it because the tftp closes the session and then the router just keeps trying. Is the 2511 boot ROM upgradable without a hardware replacement? I cant seem to find the software on ciscos site. Here is a read out of the boot process:
System Bootstrap, Version 11.0(10c)XB1, PLATFORM SPECIFIC RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1997 by cisco Systems
2500 processor with 14336 Kbytes of main memory
%SYS-4-CONFIG_NEWER: Configurations from version 11.2 may not be correctly understood.
F3: 7712364+95428+314336 at 0x3000060
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) 2500 Software (C2500-J-L), Version 11.2(5)P, SHARED PLATFORM, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1997 by cisco Systems, Inc.
Compiled Mon 07-Apr-97 12:10 by tej
Image text-base: 0x0303E4C8, data-base: 0x00001000
cisco AS2511-RJ (68030) processor (revision K) with 14336K/2048K bytes of memory.
Processor board ID 18809459, with hardware revision 00000000
Bridging software.
SuperLAT software copyright 1990 by Meridian Technology Corp).
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
TN3270 Emulation software (copyright 1994 by TGV Inc).
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
16 terminal line(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Reza Sharifi
I think, it is just old hardware.  The 2500 series have around for over 20 years now. The last IOS that was release for 2500 series was in 2007. There is no Rommon upgrade since they have been EOL for a long time.
If this is for a business, you may want to invest in a 2800 or a 2900 series as your terminal server.  If it is for home use, ebay is the place to buy used once.
This is an ebay one...and they are still pretty expensive!!
