cisco 2800 nm-1a-0c3-pom question
Hi guys I would like to know if a router 2800 support a nm-1a-0c3-pom module?
what is the recommended IOS version to use?
Thanks a lot
Yudong Wu
Level 7
Level 7
Based on the following link, nm-1a-oc3-pom is supported on 3825 and 3845 not on 2800.
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/OvrNetM.html
Giuseppe Larosa
Hello Leonardo,
a C2800 is too weak to support an OC-3 link you need a C3845
Hope to help
Giuseppe
