Cisco 2821 Clock Set Problem
Aliz_ba123
Hi dears
I have a problem with Cisco2821, I have 3 router Cisco2821
I want to set the correct clock on them, I run the "clock set xx:xx:xx Aug yy 2012",
Then wr and then reload the device
When the router comes up I enter "show clock" command.
The device show the previous time and it doesn’t change!
I don’t want to set NTP server.
Can anyone help me please?
5 Replies 5
Leo Laohoo
NTP/SNTP is the way to go.  If you don't want to set NTP/SNTP then the only method is to manually configure the time and date every reboot.
You also need to reconfigure the time in case the clock goes either too fast or too slow.
Dear leolaohoo
Thank you for answer but I have Cisco2811 and ..., and they don't have this problem,
I can set the clock on them and do reboot, then they have the correct time. And I have no NTP/SNTP.
I think this error is about my IOS or device hardware.
If you have any other solution please guide me
Maybe because you've configured "update calendar".  But even that is not accurate.
Remember that Cisco appliances do NOT have a dedicated clock/time mechanism.  They depend entirely on outside source.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Normally, the device's clock loses it time when device is rebooted (or power cycled).
Some devices also have a "calendar" which retains time across reboots (and power cycles too).
For those devices that have a "calendar", clock resets itself to calendar's current time.
Besides setting clock to current time, reset you calendar to current time too (i.e. "calendar set ...").
brian.davis
You can use an externam NTP server if the routers have access to the internet.  Just sayin...
http://support.ntp.org/bin/view/Servers/NTPPoolServers
