Cisco 2821 GRE Problems
mebernstein
I currently have a remote XP client trying to access our new vpn network from a remote location. The XP client is behind an at&t u-verse router. The flow diagram is below. I currently get a message on the XP client that GRE is not enabled or something of the sort, and it gets stuck on username and password verifying.
Flow Chart:
XP computer (192.168.1.100)
AT&t u-verse router (public ip)
Internet
Linksys RV082(192.168.0.1, public ip) configured with VPN passthrough enabled and portfowarded to allow pptp
Cisco 2821(192.168.0.100, 192.168.4.1) port fowared to allow pptp
Windows XP VPN server(192.168.4.91)
Yes i do know that the 2821 can do vpn however I was asked to do it this way.
How would i configure the 2821 (firewall is enabled) and what eles may need to be changed.
Giuseppe Larosa
Hello Michael,
GRE is another tunneling protocol an alternative to PPTP.
In your flow diagram you say you would like to setup a PPTP tunnel.
There can be combinations of the two protocols.
However, the following document can help
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_configuration_example09186a00800949c0.shtml
GRE is a protocol over IP (protocol 47)
an acl that permits GRE is written as:
access-list 111 permit gre host x.x.x.x host y.y.y.y
Hope to help
Giuseppe
