Cisco 2911 doesn´t save my settings
Hi brothers
I have a cisco 2911, I´m traying to configure it, but it doesn´t works this is wha I did.
1.-i connected to router by serial port by console
2.-Turn on the router and then show up some text like this:
Processor board ID FTX1552AKRK
3 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
         --- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: n
3.-I choose yes and I configure everything Hostname, IP addres, etc etc.
4.-When i finish I must to check one of this items, I choose 2
[0] Go to the IOS command prompt without saving this config.
[1] Return back to the setup without saving this config.
[2] Save this configuration to nvram and exit.
5.-I check the config runing-config and starup-config and I got the current settings, hostname, ip adress, etc.
6.-Everything is ok so far, but when i turn of the router I got the same text to configurate it:
Is there something grown with the router? what´s is the boot file that sould I edit to save the settings?
Thanks in advance.
11 Replies 11
Reza Sharifi
You should only get that prompt once when you setup the router for the first time.  When you get to
choose no, then go to the cli and type the host name ip address, etc...  make sure to save (wr) and then reboot.
Hi Dear Reza
I got that prompt every single time that I configure it and write to memory but when i shut down the power energy and then turn on I got the same prompt it doesn´t matter if i save the settings.
thanks for your time,
Ok, when the router boot all the way, can you issue "sh ver" and post it here?
Here is the output command sh ver
Router>sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 04-Aug-11 21:40 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M12, RELEASE SOFTWARE (fc1)
Router uptime is 3 hours, 8 minutes
System restarted at 20:05:36 UTC Fri Jul 26 2013
System image file is "flash0:c2900-universalk9-mz.SPA.150-1.M7.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 487424K/36864K bytes of memory.
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FTX1552AKRK
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            None          None           None
data          None          None           None
Configuration register is 0x2142
Thanks Reza
ok
change this
0x2142
to:
0x2102
save and reboot the router
config t
config-register 0x2102
This worked for me. On Cisco2911. Thanks.
May I ask a question,
I have done the reload process bypassed the initial config, typed en for enable conf t what the question is I know what I gave as a hostname prior to the reload, do I just type router the default and IP Address? If you'd like I can send the run start text file if that will help?
TIA for any help you may be able to give.
Jami W. "Dragon" La Croix
PunisherNET#show run
Building configuration...
Current configuration : 1210 bytes
! Last configuration change at 05:03:18 UTC Mon May 18 2020
version 15.0
hostname PunisherNET
boot-start-marker
warm-reboot
boot-end-marker
enable secret 5 $1$..xd$cG4cykUS6SReSn.Q7HKxQ1
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO2911/K9 sn FTX1521AM7B
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.2.10 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip route 0.0.0.0 0.0.0.0 192.168.2.2
ip route 0.0.0.0 0.0.0.0 192.168.1.1
control-plane
banner motd Stay Away Access Not Permitted
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
scheduler allocate 20000 1000
end
The Gods you Worship are Steele.
And at the alter of Rock 'N Roll you kneel.
Hello
Form the show running-config I can see that the router has hostname PunisherNET and also I can see that you have already configured the IP address on gi0/0 and gi 0/1.
Priyanka
Yes that is in fact true, all though if I use the reload command or the
power go which it has I have nothing but the base configuration options.
All my hard work is erased, I have a C-WS3550, C-WS3750, and a C-2960
switches that I use either write mem or copy run start on them all do the
reload command ans it boots as expected?
What I can understand from this statement of yours is that your cisco 2911 router is not booting with the saved configuration whenever it is booted.
Also, I can see that you have already made the changes with the config register, and I hope now it is 0x2102.
So, now please check if we have the boot statement in the configuration of the router or not. We should have a boot statement for the IOS image with which you want to run the router. In case if the boot statement is missing then kindly configure it on the router.
The command is as follows: Router(config)#boot system flash:<complete name of the IOS image file>
You can check the boot system using the below command.
Router# Show boot system
Priyanka
I am not clear what is the question you are trying to ask. Is it about bypassing the startup config? Or is it about saving configuration changes? Something else?
The configuration you posted seems ok, except for the 3 static default routes where only one relates to address found on the router.
Rick
