Cisco 2950 switch issue
ccnamonsun
Community Member
Q1. How Can i set Bandwidth on an interface ?
Q1. How Can i set Priority on an interface ?
Georg Pauwen
are you referring to Layer 2 or Layer 3 ports ?
For Layer 2 ports, you could use the 'storm-control' interface command to limit unicast, multicast, or broadcast traffic as a percentage of total bandwidth. For CoS priority, the 'switchport priority' command could be used.
For Layer 3 ports you have more options, such as CBWFQ and CAR. What exactly do you need to configure ?
GP
I have cisco 2950 catalyast.(layer 2)
Q1. How can i set persentage of bandwidth on a particular port ?
Q2. How can i give priority to a particular port ?
a.1) You can go to the configuration mode and then go to the interface you want to setup the bandwidth for ... and there you can set the bandwidth using bandwidth keyword.
a.2) you can set the port priority by assigning the wrr 4 queue number to the port in weight round robin queuing technique , as it will set the priority of the port high.
