05-23-2022 07:17 AM
Hii Team,
I have one issue. When I connect my Cisco switch directly through console cable it logins directly without asking any usernam and password in the putty. And I have assigned ip to the switch as well to login through gui.
But when I try to browse the ip of the switch. It's asking username and switch. But I haven't set any username and password for it. Even I tried default admin admin password also nd Cisco Cisco things and all. But still I am unable to login to the gui switch. So I need your help in getting this resolved.
Thanks and Regards,
Daiva Prasad S
prasad@athenaitsol.com
05-23-2022 08:36 AM
- Since the console access is still 'for free' , check the usernames with "show running" or configure them according to your needs.
M.
05-25-2022 03:04 AM
What happens if you leave the fields empty.
/Mikael
