Cisco 2960 - EEM
Michael Kim
Quick question.  Does our Cisco Catlayst 2960 (WS-C2960-48PST-l) support EEM (Embedded Event Manager)? Currently running code 12.2(55)SE1.
MySwitch(config)#event ?
% Unrecognized command
SW Image is C2960-LANBASEK9-M
Mike
2 Accepted Solutions
Hello Quick answer.....lol Cisco command lookup tool (CLT) states ....NO Res Paul
Kind Regards
Paul
EEM is not supported on all Cat 2K range.   This is deliberate.
EEM is supported on all Cat 3K and Cat 4K.
EDIT/UPDATE (December 2019):  EEM is supported on the Catalyst 2960X/XR starting from 15.2(4)E train.
Kind Regards
Paul
So is the feature not supported on that particular model? Do I need to upgrade from LANBASE to IPBASE to gain this feature?
Thank you for taking the time to rate our posts.
