Cisco 2960 errors on ethernet port
quezon_carlo12
Hi everyone,
Can anyone explain to me what this error means, its a port gig 1/0/1 on a 2960 switch with a cisco IP phone connected to that port.
Transmit GigabitEthernet1/0/1 Receive
687849087 Bytes 188908754 Bytes
2005532 Unicast frames 1299490 Unicast frames
311005 Multicast frames 8421 Multicast frames
198592 Broadcast frames 11826 Broadcast frames
0 Too old frames 184151318 Unicast bytes
158 Deferred frames 1281140 Multicast bytes
0 MTU exceeded frames 1932740 Broadcast bytes
122 1 collision frames 0 Alignment errors
10 2 collision frames 4 FCS errors
3 3 collision frames 0 Oversize frames
2 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
1 6 collision frames
0 7 collision frames 529963 Minimum size frames
0 8 collision frames 267019 65 to 127 byte frames
0 9 collision frames 481001 128 to 255 byte frames
0 10 collision frames 13914 256 to 511 byte frames
0 11 collision frames 14328 512 to 1023 byte frames
0 12 collision frames 13407 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 7 Symbol error frames
842 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 116 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
207355 64 byte frames 0 Valid frames, too small
483157 127 byte frames
781197 255 byte frames 0 Too old frames
50456 511 byte frames 0 Valid oversize frames
67773 1023 byte frames 0 System FCS error frames
925834 1518 byte frames 0 RxPortFifoFull drop frame
190 Too large frames
118 Good (1 coll) frames
12 Good (>1 coll) frames
7 Replies 7
Leo Laohoo
Post the complete output to the following commands:
1.  sh interface Gi 1/0/1; and
2.  sh run interface Gi 1/0/1
here are info
GigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 00da.55fc.5901 (bia 00da.55fc.5901)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:12, output 00:00:00, output hang never
Quee ueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 8000 bits/sec, 6 packets/sec
1691740 packets input, 238328325 bytes, 0 no buffer
Received 28239 broadcasts (10839 multicasts)
124 input errors, 117 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 10839 multicast, 0 pause input
3530961 packets output, 2441036049 bytes, 0 underruns
0 output errors, 138 collisions, 1 interface resets
0 unknown protocol drops
0 babbles, 842 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 pause output
Building configuration...
Current configuration : 163 bytes
interface GigabitEthernet1/0/1
switchport access vlan 8
switchport mode access
switchport voice vlan 110
speed 100
duplex full
spanning-tree portfast
end
speed 100
duplex full
The line errors caused by Collisions are because someone decided to hard-code speed and duplex settings.
This practice is an "old school" method that has no benefit whatsoever.
Remove the offending lines and the collision errors should stop.
Thanks for the info Leo..
I had it hard code due to that gi 1/0/1 is connected to a VOIP phone.. and most of the time the switch makes the port settings to half duplex..
Cisco phones don't go "half duplex" if the switch ports are set to auto/auto.   I've never seen one.
thanks for the info..
You might want to check whether your VoIP phones support speed/duplex settings.  If so, ideally, they too support auto/auto. If not, if they only support full duplex hard coded, you would need to hard code the Cisco port to match.
What you want to avoid is a duplex mismatch.
