Cisco 2960X - Automatic Shutdown port
Translator
Community Manager
Community Manager
Hello.
I have two 2960X switches in stack mode. I want to create an aggregation of two ports to two non-managable (external) switches and not Cisco. By default, by connecting both ports at the same time, the spanning-tree of the remote switches blocks both ports in the stack.
I would like to block one of the two ports as long as a port is in "up" status. If it changes to "down", I would like the second port to "up" and the other to "down". And so on.
Here is a diagram for clarity.
I was thinking of creating a Port-Channel for the link between the two ports.
Thank you.
Switch Ports Model SW Version SW Image
1 28 WS-C2960X-24PD-L 15.2(2)E6 C2960X-UNIVERSALK9-M
2 28 WS-C2960X-24PD-L 15.2(2)E6 C2960X-UNIVERSALK9-M
Leo Laohoo
Not going to work if the unmanaged switches do not support Etherchannel.
Translator
Community Manager
Community Manager
Thank you. Because switches are not managed directly by my organization, I cannot change their configurations. This is in fact an interconnection for access to external resources on which I wish to have redundancy. Is there any other way in this case, other than the Port Channel to manage this type of redundancy on the Cisco switches side?
Translator
Community Manager
Community Manager
The question is why remote switches in spannon tree block both ports is not normal.
You should take a snapshot of the BPU frames circulating on these links.
Check the spanning tree settings and if there is no protection mechanism on the switch ports of the other entity's stack.
