Cisco 3550 switch stuck at Press RETURN to get started!
Poo17
I have a cisco 3550 switch which I power cycled but now its stuck at Press RETURN to get started!
Base ethernet MAC Address: 00:XX:XX:XX:XX:XX
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 88 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 6649344
flashfs[0]: Bytes available: 9349632
flashfs[0]: flashfs fsck took 16 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Loading "flash:c3550-i9q3l2-mz.121-20.EA1a/c3550-i9q3l2-mz.121-20.EA1a.bin"...## ################################################################################ #########################################################################################################################################################################################################################################################################################################################
File "flash:c3550-i9q3l2-mz.121-20.EA1a/c3550-i9q3l2-mz.121-20.EA1a.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(20)EA1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 19-Apr-04 21:42 by yenanh
Image text-base: 0x00003000, data-base: 0x006B3454
Initializing flashfs...
flashfs[1]: 88 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 6649344
flashfs[1]: Bytes available: 9349632
flashfs[1]: flashfs fsck took 8 seconds.
flashfs[1]: Initialization complete.
...done Initializing flashfs.
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
POST: CPU Interface Tests : End, Status Passed
POST: Switch Core Tests : Begin
POST: Switch Core Tests : End, Status Passed
POST: CPU Interface 2nd Stage Tests : Begin
POST: CPU Interface 2nd Stage Tests : End, Status Passed
POST: CAM Subsystem Tests : Begin
POST: CAM Subsystem Tests : End, Status Passed
POST: Ethernet Controller Tests : Begin
POST: Ethernet Controller Tests : End, Status Passed
POST: ILP Controller Tests : Begin
POST: ILP Controller Tests : End, Status Passed
POST: Loopback Tests : Begin
POST: Loopback Tests : End, Status Passed
cisco WS-C3550-24-PWR (PowerPC) processor (revision J0) with 65526K/8192K bytes of memory.
Processor board ID CAT0911Y0R9
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:13:XX:XX:XX
Motherboard assembly number: 73-8100-09
Power supply part number: 341-0029-03
Motherboard serial number: CAT09110H76
Power supply serial number: DTH0908515V
Model revision number: J0
Motherboard revision number: A0
Model number: WS-C3550-24PWR-SMI
System serial number: CAT0911Y0R9
Peter Paluch
It seems that the switch is configured - and it is probable that its line con 0 is configured with the no exec command which would disable the command interpreter. This is a common typo when trying to disable automatic logging out - instead of no exec-timeout, people configure no exec and lock themselves out.
I suspect that this is what happened. The easiest way out of this would be to perform the password recovery procedure. Please follow the instructions in this document:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.pdf
Please let us know if you were able to recover your switch this way!
Best regards,
Peter
Aijaz Rehman
Hello dear
Flash image usually gets corrupted especially when you have electricity disruption, try below as I tried for Catalyst 3550
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html#subtopic1a
