Multicast - DR / forwarder election
D@1984
Hi, I'm trying to prefer R2 route for the multicast traffic (without using static mroute)  from R1 (receiver) to R4 (source):
Receiver (R1): 10.10.10.10
Source~(R4): 10.0.45.5
I'm completely new to multicast and still trying to understand how it works but I understand that in multi-access segments, an upstream router is selected (R2 or R3) to deal with join/prune messages. In my newtork I have changed the R2-fa0/0 - ip pim dr-prio to select it as DR however it still doesn't seem to work the way that I want it to, as traffic is still going through R3. Can the DR influence the route selection or is the route selection purely based on the RIB?
I just don't understand why whilst R2 is showing as DR, join messages are still being dealt with by R3:
message from R2: *May 12 19:06:10.035: PIM(0): Received v2 Join/Prune on FastEthernet0/0 from 192.168.123.1, not to us
this is what I see from R1:
router1# show ip pim neighbor
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
P - Proxy Capable, S - State Refresh Capable, G - GenID Capable
Neighbor Interface Uptime/Expires Ver DR
Address Prio/Mode
192.168.123.2 FastEthernet0/0 01:24:56/00:01:23 v2 200/ DR S P G
192.168.123.3 FastEthernet0/0 01:24:56/00:01:31 v2 1 / S P G
router1# show ip route 10.0.45.5
Routing entry for 10.0.45.5/32
Known via "ospf 1", distance 110, metric 114, type intra area
Last update from 192.168.123.3 on FastEthernet0/0, 01:25:41 ago
Routing Descriptor Blocks:
* 192.168.123.3, from 4.4.4.4, 01:25:41 ago, via FastEthernet0/0
Route metric is 114, traffic share count is 1
router1#show ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group,
G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
Q - Received BGP S-A Route, q - Sent BGP S-A Route,
V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(10.0.45.5, 232.1.1.5), 01:59:24/00:02:42, flags: sLTI
Incoming interface: FastEthernet0/0, RPF nbr 192.168.123.3
Outgoing interface list:
Loopback1, Forward/Sparse, 00:56:49/00:02:42
router1#show ip pim neighbor
PIM Neighbor Table
Address Prio/Mode
192.168.123.2 FastEthernet0/0 01:30:17/00:01:24 v2 200/ DR S P G
192.168.123.3 FastEthernet0/0 01:30:17/00:01:33 v2 1 / S P G
5 Replies 5
my question is around DR election and route manipulation.I used pim-pri to choose R2 as DR, but I can still see that R3 is dealing with join messages.  In my routing table R3 is the preferred path to the source for traffic, however I want R2 to be the route for multicast traffic to that specific source.
in both router
show ip igmp group
in SW
show ip igmp snooping
MHM
Torbjørn
There is an "upstream neighbor" field in the PIMv2 join message that decides which router should handle the PIM join message forwarded to the shared segment, resulting in the log message you posted from R2. You can verify this with a packet capture.
In PIMv2 the purpose of the PIM DR is to elect which router should send a PIM join when there are receivers(non PIM routers) connected to a shared segment. So if you removed PIM configuration from R1 and made it send an IGMP join, only one of the neighboring routers should send a PIM join towards the RP.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Hello
What pim mode are you using -  for information Dense mode , DR isn't required using igmpv2
sh ip pim interface detail | in ver
Kind Regards
Paul
