Cisco 3650 + Netflow configuration not working
vinayjaiswal
Level 3
Level 3
Hi Guys,
We are trying to configure netflow on Cisco 3650 switches with below configuration.
Version:   WS-C3650-48PD --- >03.07.04.E----->  cat3k_caa-universalk9 BUNDLE.
source vlan: 201------>   Gi1/0/4
Netflow Configuration:
flow record record_1
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
end
flow exporter exporter_1
destination 10.240.22.110
dscp 0
source vlan 201
transport udp 9999
end
flow monitor monitor_1
exporter exporter_1
record record_1
cache timeout active 60
end
sampler sampler_1
mode random 1 out-of 2 1024
end
int Gi1/0/4
ip flow  monitor monitor_1 input
We have whatsapp gold application to featch this data but we are unable to see any data...
Pls suggest.
Vijay
7 Replies 7
Mark Malone
is int Gi1/0/4 an ip enabled interface ? it needs to be if not
Hi Mark,
Here is the configuration of Gi 1/0/4 inteface.
interface GigabitEthernet1/0/4
 switchport access vlan 201
 switchport mode access
end
So as per your statement, we need to enable ip  for this interface. ???
Yes it will not collect on a layer 2 interface it must be layer 3 , its an IP command so works ta L3 , if you want to collect mac flows you still can but you need slightly different flow config , or else apply it to SVI 201 interface
Hi Mark,
I applied below configuration but I am getting below error whenever i tried to apply it on vlan 201.
WAN-SW01#show flow record record_1
flow record record_1:
  Description:        User defined
  No. of users:       0
  Total field space:  38 bytes
  Fields:
    match flow direction
    collect transport tcp flags
    collect interface output
    collect counter bytes long
    collect timestamp absolute first
    collect counter bytes layer2 long
WAN-SW01#show flow exporter exporter_1
Flow Exporter exporter_1:
  Export protocol:          NetFlow Version 9
  Transport Configuration:
    Destination IP address: 10.240.22.110
    Source IP address:      172.34.29.110
    Source Interface:       Vlan201
    Transport Protocol:     UDP
    Destination Port:       9999
    Source Port:            49639
    DSCP:                   0x0
    TTL:                    255
    Output Features:        Used
WAN-SW01#show flow monitor monitor_1
Flow Monitor monitor_1:
  Flow Record:       record_1
  Flow Exporter:     exporter_1
  Cache:
    Type:                 normal (Platform cache)
    Status:               not allocated
    Inactive Timeout:     15 secs
    Active Timeout:       15000 secs
    Update Timeout:       1800 secs
    Synchronized Timeout: 600 secs
WAN-SW01(config)#int vlan 201
WAN-SW01(config-if)#ip flow monitor monitor_1 input
% Flow Monitor: Flow Monitor 'monitor_1' flexible netflow not supported on vlan interfaces
Vlan 201 configuration:
interface Vlan201
 ip address 172.34.29.110 255.255.255.252
 no ip redirects
 no ip proxy-arp
 load-interval 30
end
Pls suggest.
Vijay
Must be the platform is restricting it , it can be done on 6509 for vlan interfaces , you will be restricted then just to ip based physical interfaces only if it wont take on the SVI, could also be the license is it ipbase or ipservices you have ?
interface Vlan159
ip address x.x.x.x 255.255.255.0
ip flow monitor xxxxxx input
ip flow monitor xxxxxxx output
ip pim dense-mode
load-interval 30
Hi Mark,
I really appreciate your support.
Here is current version:
System image file is "flash:cat3k_caa-universalk9.SPA.03.07.04.E.152-3.E4.bin"
I will ask end customer to configure ip based physical interfaces and then we will check.
I will update you.
Thank you.
Vijay
please check sh license right-to-use
