07-08-2016 08:31 AM - edited 03-08-2019 06:33 AM
If I have an existing Cisco 3650 LAN Base switch, WS-C3650-24TS-L, and then want to upgrade to IP Services, does the LifeTime Limited Warranty(LLW) still cove the switch? Reviewing documentation, I am confused on if you need to add SmartNet, and what level of SmartNet. Is there a document(s) that describe these process(es)?
07-08-2016 09:22 AM
Licensing and warranty/Smartnet are 2 different things. You pay for the license (it is a one time fee) to upgrade from LAN Base to IP services. You purchase warranty/Smartnet for so many years to be able to download IOS and do RMAs.
07-08-2016 10:35 AM
I know the difference between Licensing and Warranty/SmartNet. Once you change the license, what are your options for maintenance?
