Cisco 3650
t.oliver1
has anybody had any problem with 3650 and connecting to use the express setup? the quick guide says to put into express mode and use ip 10.0.0.1 for switch, the problem is the switch doesn't give out that range dhcp it is 10.0.2.1, the manual is from cisco website so must be out of date, anybody where i can get the latest?
InayathUlla Sharieff
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/hardware/installation/guide/Cat3650hig_book/HGcliSET.html
Ganesh Hariharan
Try This..
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/hardware/quick/guide/3560gsg_08.html
Hope that Helps..
-GI
