Cisco 3750 --- Cannot mark http traffic with DSCP ef, from an inside web server
Samuel Petrescu
Good afternoon,
I am trying to mark http packets from a web server with DSCP ef, but when I am doing a traffic capture all http packets have tos 0x0
I am able to mark UDP and ICMP packets originated from this server, but not any TCP traffic.
The web server is in VLAN 20
This is my config
mls qos
ip access-list extended MARK-HTTP-ACL
  permit tcp host 10.10.10.10 eq www any
class-map match-any HTTP-CM
match access-group name MARK-HTTP-ACL
policy-map PRIORITY-PM
class HTTP-CM
  set dscp ef
interface GigabitEthernet1/0/11
switchport access vlan 20
switchport mode access
spanning-tree portfast
mls qos trust dscp
service-policy input PRIORITY-PM
Can anybody help me understanding, what I am doing wrong?
Thank you
Sam
cadet alain
how are you marking your non tcp traffic ?
Regards.
Alain
Thank you for answering.
I am marking different traffic, just changing the ACL MARK-HTTP-ACL
I tested with this, and is working, but are ICMP packets
Ip access list MARK-HTTP-ACL
permit icmp any any
Thank you
Sam
Hi Samuel,
I belive that if you "trust dscp" , if you trust it will not change it . So one solution is to remove trust dscp.
If you still want to trust other dscp markings :
class HTTP-CM
  set dscp ef
class class-default
  trust dscp
Dan
Thank you for spending time with my problem.
I took out the "trust dscp" and didn’t work; even I couldn’t mark icmp packets anymore.
I will set up a lab environment during the weekend, to be able to do more testing.
Thank you
Sam
