Cisco 3750 connect to 3com Baseline 2900 series
humberjet
Good afternoon.
We need to implement VLANs on my company's network.
I have 3750 L3 swtich, ive setup 3 vlans for testing. ive setup SVI everything.
now how do I connect it to 3com that will also use VLANs.
should I set trunk port of cisco and 3com? or no need?
pls help
Reza Sharifi
If the 3com switch is your access layer switch and the 3750s are distro/core than you need to create a trunk between the 3com and the 3750
ive setup both in trunking but no luck i cant ping my svi thru 3com switch..
what would be the conf of 3750.. should i set it to nonego?
