Cisco 3750 E series Power fluctuation issue
schnkumar331
I am new to networking. I want to check how many times my switch has been restarted. Is there any way to check this.
So that i can check all power fluctuations due to which switch went down.
Jitender Bhandari
I think you should move this to switching section to get better help.
you can try "show log" to see if that information is there.
JB
Mark Malone
You can check the last time it went down with show version but unless your using some 3rd party monitoring or the switch is setup to send syslogs then no you wont be able to seethe pervious times before that
unfortunately the standard logs are wiped during a reboot as there stored in nvram
Router(config)#logging host
Specifies the syslog server by IP address or host name; you can specify multiple servers.
