Cisco 3750 enable password reset
karamak2
All,
I have a question enable password reset for Cisco 3750. I just took over from someone and do not have the enable password to view the configuration for Cisco 3750. Is there anyway to reset the enable password without wiping the current configuration?
acampbell
You need to follow this set if instructions:-
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.html
Alex
Regards, Alex. Please rate useful posts.
