Cisco 3750 Issues with Network Assistant
SF02
I have two stacks of 3750 switches with the following configuration:
1:ws-c3750g-12s
2:ws-c3750g-12s
3:ws-c3750g-12s
4:ws-c3750g-48ts
5:ws-c3750v2-24ts
I have just upgraded the software to the Cryptographic Services image in order to use SSH rather than telnet for CLI management. The image I am using is c3750-ipbaselmk9-tar.122-55.SE4 and it was upgraded using the tarball with archive download-sw.
I have enabled SSH and HTTPS using the following commands:
ip domain-name xxxxxx
crypto key generate rsa
ip ssh version 2
ip ssh time-out 60
ip ssh authentication-retries 3
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
no ip http server
ip http secure-server
ip http authentication local
I can now SSH to the stack CLI and use HTTPS from a web browser but when trying to connect with Cisco Network Assistant I get an unable to connect message. The only way I have been able to get this to work is to enable ip http server. Has anyone else encountered this issue and knows how to resolve?
Phill
krhashbarger
I have had the same issue, with the newer version of Network Assistant. I get the message on my 3750's, 2960 switches, which are running IOS 122-53.SE2 with Web device Manager. This is with Verison 5.7 that I get this all the time. I ended up down-grading to the 5.6 which does not give me this problem. I believe there is something wrong with the 5.7 version that is preventing any https connections to switches. CISCO NEEDS TO FIX the PROGRAM.
6 Replies 6
Latchum Naidu
Hi Sihanu,
See the below link will help you.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/hardware/quick/guide/3750GSG3.html#wp56728
Please rate all the helpfull posts.
Naidu.
I can't see anything in the documentation you have linked which refers to the problem I am having. Can you be more specific please.
Phill
krhashbarger
I'm glad it's not just me, I noticed today I am also getting this issue on my aironet APs. I recently updated to 5.7 of CNA before I began moving to using SSH and HTTPS.
I will try downgrading to 5.6 and confirm if this resolves the problem for me.
Cheers,
SF02
As per what krhashbarger posted, I downgraded CNA to 5.6.3 and this now works for all my HTTPS devices.
I agree that this seems to be a problem with version 5.7 which needs to be addressed by Cisco.
Thanks for the help.
No problem, glad to help. Hopefully Cisco will come out with a fix soon for this problem.
