cisco 3750 stack cpu utilisation
euandrian
Community Member
Hi!
i have two cisco 3750 in stack
firts, master switch have all swports busy
second have only 5
how can i see cpu utilizations of the second switch, and its reasonable to move somme devices from first switch to second for
deacreases of cpu and memory utilisations of the master?
the stack tehnologies use both cpu as one? or its only for simple management ?
i realy need an answer now!
googl did nt say this
thanks for help if someone know!
HI Adrian,
Only the Master Switch will do all the processing and not the standby switches.
The CPU doesnt load balance in the stack switches.
Inayath
10 Replies 10
InayathUlla Sharieff
Hi Adrian,
Could you please let me know whats the current CPU utlization on the switch?
Also kindly provide me the following outputs:
show version
show proc cpu sorted | ex 0.0
show proc cpu history
show controllers cpu-interface
show platform port-asic stats drop
Inayath
hi, there are sh version
C3750G_B#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 02-Dec-10 07:46 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
C3750G_B uptime is 6 days, 22 hours, 25 minutes
System restarted at 16:59:30 Moldova Thu Feb 14 2013
System image file is "flash:/c3750-ipservicesk9-mz.122-55.SE1.bin"
_______-------_______
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C3750G-48TS (PowerPC405) processor (revision C0) with 131072K bytes of memory.
Processor board ID FCZ1427701X
Last reset from power-on
2 Virtual Ethernet interfaces
104 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : A8:B1:D4:xx:xx:xx
Motherboard assembly number     : xx-xxxxx-08
Power supply part number        : 341-0107-01
Motherboard serial number       : FOCxxxxxxx
Power supply serial number      : AZS1412xxxx
Model revision number           : C0
Motherboard revision number     : G0
Model number                    : WS-C3750G-48TS-S
System serial number            : FCZ142xxxxX
Top Assembly Part Number        : xxx-xxx57-02
Top Assembly Revision Number    : D0
Version ID                      : V04
CLEI Code Number                : COM7Xxxxxx
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
     1 52    WS-C3750G-48TS     12.2(55)SE1           C3750-IPSERVICESK9-M
*    2 52    WS-C3750G-48TS     12.2(55)SE1           C3750-IPSERVICESK9-M
Switch 01
Switch Uptime                   : 6 days, 22 hours, 25 minutes
Base ethernet MAC Address       : 00:21:1B:xx:xx:xx
Motherboard assembly number     : 73-xxx18-08
Motherboard serial number       : FOC1213456D
Power supply serial number      : AZS120525W7
Model revision number           : F0
Motherboard revision number     : C0
System serial number            : FOC121xxxx
Top assembly part number        : 800-26857-02
Top assembly revision number    : A0
Version ID                      : V04
Configuration register is 0xF
C3750G_B#show proc cpu sorted | ex 0.0
CPU utilization for five seconds: 7%/1%; one minute: 16%; five minutes: 20%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
110     5225409   1235530       4229  0.79%  0.82%  0.80%   0 hpm counter proc
  92     4005757     59504      67319  0.47%  0.69%  0.64%   0 HULC Tcam Memory
159     2107192    119041      17701  0.31%  0.32%  0.31%   0 HQM Stack Proces
225     2105331  11776683        178  0.15%  0.19%  0.25%   0 Spanning Tree
Hi Adrian,
Currently CPU Utilization is just 7%. When did you see the spike in the cpu?
REgards
Inayath.
at the moment its all right, but i have somme hours when its 90%, and somme aplications are very sensible to late response(sorry for my english, can you anderstand?)
C3750G_B#show controllers cpu-interface
ASIC    Rxbiterr   Rxunder    Fwdctfix   Txbuflos   Rxbufloc   Rxbufdrain
ASIC0     0          0          0          0          0          0
ASIC1     0          0          0          0          0          0
ASIC2     0          0          0          0          0          0
ASIC3     0          0          0          0          0          0
ASIC4     0          0          0          0          0          0
ASIC5     0          0          0          0          0          0
ASIC6     0          0          0          0          0          0
ASIC7     0          0          0          0          0          0
ASIC8     0          0          0          0          0          0
ASIC9     0          0          0          0          0          0
ASICA     0          0          0          0          0          0
ASICB     0          0          0          0          0          0
ASICC     0          0          0          0          0          0
HOL Fix Counts
No Fixes:          0 Added:          0 In Use:          0 Both:          0
CPU Heartbeat Statistics
Tx Success Tx Fail    1st Thr    2nd Thr    Unthr      RetryCtMax
  11893472          0          0          0          0          1
Rx Delay
         0          1          2          3          4
  11893472          0          0          0          0
AddlDelay AdvanceCnt
         0          0
Rx Retries by RetryCount
         0          1          2          3          4          5          6
  11893472          0          0          0          0          0          0
         7          8          9
         0          0          0
AddlRetry
cpu-queue-frames  retrieved  dropped    invalid    hol-block  stray
rpc               12011505   0          0          0          0
stp               21454820   0          0          0          0
ipc               640019     0          0          0          0
routing protocol  22086807   0          0          0          0
L2 protocol       338874     0          0          0          0
remote console    774        0          0          0          0
sw forwarding     45220      0          0          0          0
host              37917373   0          0          0          0
broadcast         7406726    0          0          0          0
cbt-to-spt        0          0          0          0          0
igmp snooping     17826631   0          0          0          0
icmp              0          0          0          0          0
logging           0          0          0          0          0
rpf-fail          0          0          0          0          0
dstats            0          0          0          0          0
cpu heartbeat     11893591   0          0          0          0
cpu-queue         static inuse static added
rpc               0            0
stp               0            0
ipc               0            0
routing protocol  0            0
L2 protocol       0            0
remote console    0            0
sw forwarding     0            0
host              0            0
broadcast         0            0
cbt-to-spt        0            0
igmp snooping     0            0
icmp              0            0
logging           0            0
rpf-fail          0            0
dstats            0            0
cpu heartbeat     0            0
Supervisor ASIC receive-queue parameters
queue 0 maxrecevsize 7E0 pakhead 55A5CE0 paktail 4877658
queue 1 maxrecevsize 7E0 pakhead 561E7AC paktail 562B1CC
queue 2 maxrecevsize 7E0 pakhead 55C8640 paktail 55C82A4
queue 3 maxrecevsize 7E0 pakhead 4D12840 paktail 4D0C330
queue 4 maxrecevsize 7E0 pakhead 56322F4 paktail 49D9640
queue 5 maxrecevsize 7E0 pakhead 4CE926C paktail 57C32A8
queue 6 maxrecevsize 7E0 pakhead 4CFCC7C paktail 57CFAC4
queue 7 maxrecevsize 7E0 pakhead 4CB9344 paktail 573B3C8
queue 8 maxrecevsize 7E0 pakhead 4CCB404 paktail 5751328
queue 9 maxrecevsize 7E0 pakhead 56E3CDC paktail 56E3CDC
queue A maxrecevsize 7E0 pakhead 4B7B138 paktail 4B7AA00
queue B maxrecevsize 7E0 pakhead 4D15E64 paktail 57EA98C
queue C maxrecevsize 7E0 pakhead 4B8BCF4 paktail 56F3E9C
queue D maxrecevsize 7E0 pakhead 4B8365C paktail 56E3940
queue E maxrecevsize 0 pakhead 0 paktail 0
queue F maxrecevsize 7E0 pakhead 4B71F04 paktail 56C4FD8
Supervisor ASIC exception status
Receive overrun    00000000   Transmit overrun 00000000
FrameSignatureErr  00000000   MicInitialize    00000000
BadFrameErr        00000000   LenExceededErr   00000000
BadJumboSegments   00000000
Supervisor ASIC Mic Registers
MicDirectPollInfo               80000200
MicIndicationsReceived          00000000
MicInterruptsReceived           00000000
MicPcsInfo                      0000001F
MicPlbMasterConfiguration       00000000
MicRxFifosAvailable             00000000
MicRxFifosReady                 0000BFFF
MicTimeOutPeriod:       FrameTOPeriod: 00000EA6 DirectTOPeriod: 00004000
MicTransmFramesCopied           00000003
MicTxFifosAvailable             00001FFF
MicConfiguration:       Conf flag: 00000110     Interrupt Flag: 0000000A
MicReceiveFifoAssignmen Queue 0 - 7: 00000000   Queue 8 - 15:00000000
MicReceiveFramesReady:  FrameAvailable: 00000001        frameAvaiMask: 00000000
MicException:
        Exception_flag  00000000
        Message-1       00000000
        Message-2       00000000
        Message-3       00000000
MicIntRxFifo:
        ReadPtr         00000368        WritePtr        00000368
        WHeadPtr        00000368        TxFifoDepth     C0000800
MicIntTxFifo:
        ReadPtr         00000E98        WritePtr        00000E98
        WHeadPtr        00000E98        TxFifoDepth     C0000800
MicDecodeInfo:
Fifo0:  address:        03FF4000 asic_num:      00000100
Fifo1:  address:        03FF4400 asic_num:      00000101
MicTransmitFifoInfo:
Fifo0:   StartPtrs:     066EC800        ReadPtr:        066ECA90
        WritePtrs:      066ECA90        Fifo_Flag:      8A800800
        Weights:        001E001E
Fifo1:   StartPtrs:     06427400        ReadPtr:        06427630
        WritePtrs:      06427630        Fifo_Flag:      89800400
        Weights:        000A000A
MicReceiveFifoInfo:
Fifo0:  StartPtr:       06700000        ReadPtr:        06700278
        WritePtrs:      067002D8        Fifo_Flag:      8B000FA0
        writeHeaderPtr: 067002D8
Fifo1:  StartPtr:       069B9C00        ReadPtr:        069B9DF8
        WritePtrs:      069B9DF8        Fifo_Flag:      89800400
        writeHeaderPtr: 069B9DF8
Fifo2:  StartPtr:       06972400        ReadPtr:        069724C8
        WritePtrs:      069724C8        Fifo_Flag:      89800400
        writeHeaderPtr: 069724C8
Fifo3:  StartPtr:       06BCEC00        ReadPtr:        06BCED30
        WritePtrs:      06BCED30        Fifo_Flag:      89800400
        writeHeaderPtr: 06BCED30
Fifo4:  StartPtr:       06A01400        ReadPtr:        06A015E8
        WritePtrs:      06A015E8        Fifo_Flag:      89800400
        writeHeaderPtr: 06A015E8
Fifo5:  StartPtr:       06B3E200        ReadPtr:        06B3E230
        WritePtrs:      06B3E230        Fifo_Flag:      88800200
        writeHeaderPtr: 06B3E230
Fifo6:  StartPtr:       06B85000        ReadPtr:        06B85120
        WritePtrs:      06B85120        Fifo_Flag:      89800400
        writeHeaderPtr: 06B85120
Fifo7:  StartPtr:       06AADC00        ReadPtr:        06AADD98
        WritePtrs:      06AADD98        Fifo_Flag:      89800400
        writeHeaderPtr: 06AADD98
Fifo8:  StartPtr:       06B18200        ReadPtr:        06B18338
        WritePtrs:      06B18338        Fifo_Flag:      88800200
        writeHeaderPtr: 06B18338
Fifo9:  StartPtr:       066FECD8        ReadPtr:        066FECD8
        WritePtrs:      066FECD8        Fifo_Flag:      82800008
        writeHeaderPtr: 066FECD8
Fifo10: StartPtr:       066EC200        ReadPtr:        066EC3F0
        WritePtrs:      066EC3F0        Fifo_Flag:      88800200
        writeHeaderPtr: 066EC3F0
Fifo11: StartPtr:       066FFF00        ReadPtr:        066FFF00
        WritePtrs:      066FFF00        Fifo_Flag:      86800080
        writeHeaderPtr: 066FFF00
Fifo12: StartPtr:       06A77C00        ReadPtr:        06A77F00
        WritePtrs:      06A77C00        Fifo_Flag:      89000100
        writeHeaderPtr: 06A77C00
Fifo13: StartPtr:       066FFE00        ReadPtr:        066FFE00
        WritePtrs:      066FFE00        Fifo_Flag:      86800080
        writeHeaderPtr: 066FFE00
Fifo14: StartPtr:       00000000        ReadPtr:        00000000
        WritePtrs:      00000000        Fifo_Flag:      00800000
        writeHeaderPtr: 00000000
Fifo15: StartPtr:       064272C0        ReadPtr:        064272D8
        WritePtrs:      064272D8        Fifo_Flag:      84800020
        writeHeaderPtr: 064272D8
Complete Board Id:0x4011
Hi Adrian,
Currently everything seems to be okay to me. Usualy high cpu utilization are troubleshooting during the issue to isolate and find the culprit which is causing the cpu to go high.
Inayath
my main question is if both cpu are used as one or every one is used its own cpu separateley?or there are somthink like """"load balansinc""?
HI Adrian,
Inayath
thank you Inayath!
Regards!
