05-15-2009 12:33 PM - edited 03-06-2019 05:45 AM
We have two stacked 3750 switches that have been rebooting for several days. Is there a way to check which switch has been rebooting by checking the uptime? The show version only shows 1 uptime.
We need to make sure that we replace the bad switch.
Thanks.
05-15-2009 01:35 PM
Hello Richard,
try to use show switch.
However, be aware that the master if reloaded make all switches in the stack to reload.
So the uptimes could be equal if it is the master the one that reloads first.
see the following doc about troubleshooting stacks
Hope to help
Giuseppe
05-15-2009 01:50 PM
Thanks Giuseppe. The "show switch" shows both are ready.
We recently added the second switch. That's when the rebooting started happening. It could be the second switch. We can try to replace it and see what happens. Thanks for the link.
05-15-2009 06:40 PM
Can you find a crashinfo file when you do the following commands:
dir flash:
dir flash1:
If you do, can you post/attach the file?
