Cisco 3750-X 'no shutdown' not working
pronin_sergey
I'm experiencing strange issue with my WS-C3750X-48T-S.
Model number                    : WS-C3750X-48T-S
System image file is "flash:/c3750e-universalk9-mz.122-55.SE3/c3750e-universalk9-mz.122-55.SE3.bin"
This switch is situated on a remote site and on the 6th of January it was rebooted.
I still do not know the cause, but it might be power outage or smth. We are still checking.
After the reboot I've noticed that one port on this cisco switch is in 'notconnect' state, while I'm pretty sure it should be 'connected'.
I've tried to shutdown the port adminstratevly and do the 'no shutdown' but this port remained in 'disable' state.
#sh run interface Gi1/0/5
Building configuration...
interface GigabitEthernet1/0/5
switchport access vlan 111
switchport mode access
shutdown
no cdp enable
no cdp tlv server-location
no cdp tlv app
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
end
#conf t
(config)#interface GigabitEthernet1/0/5
(config-if)#no shutdown
(config-if)#end
#sh run interface GigabitEthernet1/0/5
shutdown
no cdp enable
no cdp tlv app
end
What might cause this problem?
Sergey
pronin_sergey
Looks like I've found smth in the logs:
Jan  7 06:10:58.357: %PLATFORM_ENV-3-LOOPBACK_PORT_POST_ERR: Gi1/0/5 can't be brought up because it failed POST in Loopback test.
Is that port damaged?
Hi Sergey,
Yes, it is HW issue of the faulty port in your case (error is reported by the port ASIC).
There is also a known bug producing the same symptoms but it is already fixed in the release you are currenty running:
    CSCti75491 WS-C3750X-24T-L some ports failed POST in Loopback test .
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
