Cisco 3750
MajidShirzadeh
Hello, I have 2 IDF in one floor, each IDF has 4 3750 stack, what's the best practice ? Do I need individual subnet per IDF or I can use 1 subnet for 2 IDFs ? I have data and voice VLAN . Thanks
riley.porter
You can use one subnet for the entire floor if you want to, it's all up to you. Your voice and data VLANs can be separate (SWITCHPORT VOICE VLAN ##);(SWITCHPORT ACCESS VLAN ##), respectively.
For us, we currently use a VLAN per department; however, we are switching to one VLAN per closet to make management a bit easier. I think best practice comes down to how you want to split and/or restrict your layout. But, certainly a VLAN isn't restricted to a device (or stack
Thanks for your help Riley !
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Best practice is to avoid extending VLANs across multiple 3750 stacks.
