Cisco 3750G series switch
We have a switch that needs to be replaced. I believe it's still under warrenty.
How do I go about this?
Russ
Reza Sharifi
Hi Russ,
You need to open TAC case at Cisco.com. They will let you now how to go for replacing it
Reza
Itzcoatl Espinosa
Hi Russ,
I think the best way is to go to www.cisco.com website and click on Support > Open a service request. you can enter the serial number from the switch, verify if it is under warranty. The page will guide you so that you can open a case and have the switch replaced.
Itzcoatl Espinosa.
Thanks for the help.
I got it called in for a service request.
Russ
Itzcoatl Espinosa
anytime
