Cisco 3750X Switch, Observing change in Running & Startup Config
Sanjay S N
I have a cisco catalyst 3750X switch running with c3750e-universalk9-mz.152-1.E1.bin, where I'm able to see the running configuration & Startup configuration on the device is not in Sync even after saving configuration to the NVRAM.
Startup Configuration is the one which is required for my network to work properly, but as I'm able to see running configuration is adding some of the configuration which is not actually required in the template. Can anyone help me to get this issue addressed.
Configuration attached.
InayathUlla Sharieff
Can you try this command:
Switch#copy startup-config running-config
And then check if you are still face the same issue?
Inayath
Akash Agrawal
We may see such issue due to low NVRAM battery as well. Please check syslog if you are getting any error related to NVRAM. If there are no errors, you can try to save running config to the flash and then relaod the switch. after booting up, replace running config with config saved in the flash. try to save again in the NVRAM.
--Pls dont forget to rate helpful posts--
Akash
