Cisco 3750x with Access Point
jacob6000
I have an access point connected to a 3750x switch. It looks like it isn't drawing enough power because I get an amber power light. I had this problem once before with a different switch vendor and I hard to configure some specific commands. After that, the power consumption was around 17W.
How do I verify that the correct power is being negotiated with LLDP?
Is there a way to force a higher PoE usage?
Thank you,
Leo Laohoo
Someone has already responded to the thread in reddit.
What other information is provided?
