01-10-2017 06:22 PM - edited 03-08-2019 08:52 AM
hi,
we got a 3850 that's reporting to have constant high CPU.
our team is considering an IOS upgrade but i ran into this site below and suggesting to enable this command ipv6 mld snooping.
my question is, does someone ran into the same issue and solved it by applying the said command?
is this safe to enable this command in a production switch?
https://www.theroutingtable.com/cisco-3850-high-cpu-usage-fed-and-iosd-processes/
#sh ve
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.03.SE RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 23-Sep-13 18:24 by prod_rel_team
<SNIP>
Switch Ports Model SW Version SW Image Mode
1 56 WS-C3850-48P 03.02.03.SE cat3k_caa-universalk9 INSTALL
#show processes cpu sorted
Core 0: CPU utilization for five seconds: 77%; one minute: 71%; five minutes: 71%
Core 1: CPU utilization for five seconds: 28%; one minute: 71%; five minutes: 78%
Core 2: CPU utilization for five seconds: 96%; one minute: 72%; five minutes: 67%
Core 3: CPU utilization for five seconds: 99%; one minute: 90%; five minutes: 91%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
5632 547159 38565649 240 73.91 73.47 73.38 1088 fed
9223 2869678 17955697 98 0.97 1.17 1.15 0 iosd
6297 1592710 28366670 1186 0.14 0.15 0.14 0 cpumemd
6278 403412 5609218 837 0.10 0.01 0.03 0 oom_poll.sh
9219 3878616 89615676 25 0.10 0.10 0.10 0 wcm
5633 2355637 33902453 13 0.05 0.14 0.12 0 platform_mgr
5634 918091 19813894 41 0.05 0.06 0.05 0 stack-mgr
6286 605408 34263960 50 0.05 0.09 0.10 0 pdsd
6290 905582 23382817 22 0.05 0.01 0.01 0 netd
1 1650 1056 1562 0.00 0.00 0.00 0 init
2 0 126 0 0.00 0.00 0.00 0 kthreadd
3 9620 1171075 8 0.00 0.00 0.00 0 migration/0
4 0 3 0 0.00 0.00 0.00 0 sirq-high/0
5 1139468 45134130 2 0.00 0.00 0.00 0 sirq-timer/0
6 0 6 0 0.00 0.00 0.00 0 sirq-net-tx/0
7 10 9636 1 0.00 0.00 0.00 0 sirq-net-rx/0
8 1180 2734379 0 0.00 0.00 0.00 0 sirq-block/0
9 0 8 0 0.00 0.00 0.00 0 sirq-block-iopo
10 20 3286 6 0.00 0.00 0.00 0 sirq-tasklet/0
#show process cpu detail process fed sorted
Core 0: CPU utilization for five seconds: 67%; one minute: 61%; five minutes: 63%
Core 1: CPU utilization for five seconds: 90%; one minute: 63%; five minutes: 68%
Core 2: CPU utilization for five seconds: 44%; one minute: 77%; five minutes: 74%
Core 3: CPU utilization for five seconds: 99%; one minute: 98%; five minutes: 96%
PID T C TID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
5632 L 1730899 3856815 240 73.05 73.39 73.34 1088 fed
5632 L 1 9959 3858823 1188680 0 24.13 24.15 24.13 0 PunjectRx
5632 L 3 9957 1862104 1126280 0 24.08 24.16 24.15 0 Replenish
5632 L 2 9934 3063734 1230300 0 18.38 18.48 18.28 0 Xcvr
5632 L 0 10126 1153414 2162711 0 5.74 5.73 5.90 0 XcvrPoll
5632 L 0 6089 719166 5508445 0 0.43 0.42 0.43 0 fed-ots-nfl
5632 L 0 6086 381850 7773271 0 0.10 0.21 0.19 0 fed-ots-main
5632 L 0 6117 1693000 1885126 0 0.10 0.14 0.14 0 IntrDrv
5632 L 0 9960 3774407 6739445 0 0.10 0.08 0.08 0 PunjectTx
5632 L 1 5632 31910 7488 0 0.00 0.00 0.00 1088 fed
5632 L 2 6073 3951458 5714392 0 0.00 0.04 0.02 1088 fed
5632 L 3 6074 30 1482 0 0.00 0.00 0.00 1088 fed
5632 L 2 6075 3178510 2822516 0 0.00 0.03 0.04 1088 fed
Solved! Go to Solution.
01-11-2017 02:14 PM
John,
What is the uptime of this switch and stack?
Denali is the "new" IOS for the 3650/3850, version 16.X.
I understand the reluctance to make a decision to bounce the switch, however, the have been known vulnerabilities and, possibly, crashes from this version.
I didn't bother chasing up BTK if the high CPU is, in any way, related to the version currently running on this switch.
01-11-2017 06:57 PM
Pre,
There is no need to change the boot variable statement if you're using the "software install" command.
Please don't forget to run the "software clean" so that the contents of the flash doesn't look like a Chinese take-away menu.
01-10-2017 10:32 PM
John,
3.2.3 is a very, very old IOS. I think it's best to upgrade to 3.7.X or Denali.
01-10-2017 10:57 PM
leo,
pre, what's Denali?
how about the command mentioned? will it solve the high CPU issue without IOS update?
01-11-2017 02:14 PM
John,
01-11-2017 05:07 PM
thanks! will go the IOS upgrade route.
01-11-2017 08:59 PM
Thanks for taking the time to rate our post(s), pre. :)
01-15-2017 05:16 PM
hi leo,
sorry just got another question that pop up.
i'll be doing the 3850 switch upgrade remotely.
can you execute the software install command remotely or need this to be via console?
i saw there's some macros executed and then asked to reboot.
[1 ]: Finished installing software. New software will load on reboot.
[1 ]: Committing provisioning file
[1 ]: Do you want to proceed with reload? [yes/no]: yes <<< WILL I STILL HAVE REMOTE SSH ACCESS UP TO THIS POINT?
01-15-2017 06:55 PM
Can be done remotely.
Once you answer "y" the stack will reload.
01-11-2017 06:15 PM
pre,
referring to link below about the 3850 IOS upgrade using the software install command:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117552-technote-cat3850-00.html
do i need to put a boot sequence command?
boot system switch all flash:<NEW IOS>.bin
the 3850 switch that i'll be upgrading has or running on .pkg file (no .bin file).
01-11-2017 06:57 PM
Pre,
06-27-2019 08:20 AM
Greetins,
We have the same issue.
We actived the IPv6 mld snooping command and nothing happenen; the high cpu consumption due to fed proccess still persist.
We have being searching for almost two days and haven't anything to resolve this.
Is there any other way out of this? update? power cicle the equipment??
