Cisco 3850 Netflow Flexible - confused about input / output interface
SJ K
Level 5
Level 5
Hi all,
How is "input" and "output" for an interface define ?
If there is "traffic" routed/switched from within the switch and waiting to be send out by an interface, is that consider "input" or  "output" ?
e.g.  traffic comes into gi1/0/1 and need to be send out from gi1/0/2) , is that "traffic"consider as input to gi1/0/2 or output for gi1/0/2 ?
While reading Cisco 3850 FNF, the following confused me extremely.
If you apply a flow monitor in the input direction:
 • Use the match keyword and use the input interface as a key field.
 • Use the collect keyword and use the output interface as a collect field. This field will be present in the exported records but with a value of 0.
• If you apply a flow monitor in the output direction:
 •  Use the match keyword and use the output interface as a key field.
 • Use the collect keyword and use the input interface as a collect field. This field will be present in the exported records but with a value of 0.
So i apply a flow in input direction so as to monitor input traffic, but the collect will be using an output interface and it will always be a value of 0 ?
Can some gurus tell me how to intepret the above please ?
Confused Noob
sysad43
No one ever answered this, but my understanding is input is data coming into the switch from the interface (ie external). Output is being data being put on the interface by the switch to be sent out to external device.
