Cisco 3850 SSO and NSF failover time
Russ Kwong
Dear Member,
I m trying to setup a network with few second fail-over with Cisco 3850 stack, C3850 support SSO and NSF on OSPF.
However, when the Master fails, Slave take up the role and re-learn routing information and around 10 sec to fail-over.
May any brothers have this experience and 10 sec fail-over should be the normal behavior or can be enhance?
Attach diagram for reference.
Russ
Reza Sharifi
10 seconds is a little too high.
can you add this command to the stack and test again?
stack-mac persistent timer 0
Great, adding the following command and only have 1 ping loss with end to end.
Stack-mac persistent timer 0
router ospf 1
nsf cisco enforce global
