08-13-2019 09:32 AM
So I am stacking two separate 3850 Stacks together. They are in separate buildings. I am using sfp ports, both stacks have NM4-1G modules. I am configuring one link between the two and cannot get any data to pass between the two.
The links show up/up, the Lights on both ends are green, If i shutdown one side, the other side goes down aswell. However, the switches are not discovering eachother via cdp and it is enabled. This is really odd. Both ends have a simple "switchport mode trunk" command configured. Any ideas??
Thanks!
08-13-2019 09:57 AM - edited 08-13-2019 10:00 AM
Can you post "sh run" from both switches and point out the interface number connecting them together?
If you are using the 1Gig fiber port, it should be gi1/1/x
01-14-2020 10:52 AM
I recently switched jobs so I haven't been logged on here in a bit. I wanted to update this thread with the solution to my problem.
To recap, I was having an issue with trunking two switch stacks together. This simple task had me beat for two days. No matter the configuration, the two switches would not form a trunk. On the second day I finally decided to check the mac address table to see what mac address the switch was listing for the trunked port. This is when I found that the switch was not listing any mac addresses. This issue was caused by a Bug and after updating the code on these switches they worked perfectly. I am writing this from memory so I do not remember the specific bug #.
01-14-2020 11:44 AM
