Cisco 385048P-S Switch will not boot...Flash is in read-only mode.
Here's what I got.  It only boots into ROMMON mode.
switch: dir
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
bs[3]: (read-only)
usbflash0[10]: (read-write)
flash[19]: (read-only)
tftp[20]: (read-write)
switch: dir flash:
Directory of flash:/
77601 drwx 4096 .
2 drwx 4096 ..
77602 -rw- 2097152 nvram_config
77603 -rw- 83284288 cat3k_caa-base.SPA.03.06.09E.pkg
77604 -rw- 3949504 cat3k_caa-drivers.SPA.03.06.09E.pkg
77605 -rw- 33805552 cat3k_caa-infra.SPA.03.06.09E.pkg
77606 -rw- 42815044 cat3k_caa-iosd-universalk9.SPA.152-2.E9.pkg
77607 -rw- 28460176 cat3k_caa-platform.SPA.03.06.09E.pkg
77608 -rw- 112671812 cat3k_caa-wcm.SPA.10.2.190.0.pkg
77609 -rw- 1237 packages.conf
switch: set
CSR_PCIERST_DISCONNECTED=yes
Here is the boot process:
Booting...Initializing RAM +++++++@@@@@@@@...++++++++++++++++++++++++++++++++
Base ethernet MAC Address: 00:57:d2:33:80:80
Interface GE 0 link down***ERROR: PHY link is down
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 2 seconds....done Initializing Flash.
file name too long
The system is unable to boot automatically. The
BOOT environment variable needs to be set to a
bootable image.
Here is the boot process when trying to boot from USB:
Leo Laohoo
If the switch is still in ROMMON, I want to see the complete output to the command "set" and "dir flash:".
